Other mesh networks such as Eero and soon Luma support hard wiring your sattelites. I think its extremely important Netgear Orbi does the same. Especially for those of us who can.
peteytesting
Apr 21, 2017Hero
the different requirement of the wired backhaul then remove the orbi as a solution , but there are lots of wireless router that will run in AP mode that will solve you problem and give you the ports you need as well
im not arguing against it , im saying if it hasnt been added by now its not going to get added . you may see it in a different version of the orbi but seeing as the newly released rbk 40 and 30 still dont have wired backhaul i cant see it happening even with the amount of ppl posting here and else where
sure the ap in the other building will work as an ap would normally work but wont interact with the orbi in a firmware sense but it should work fine otherwise
