Other mesh networks such as Eero and soon Luma support hard wiring your sattelites. I think its extremely important Netgear Orbi does the same. Especially for those of us who can.
218 Comments
- thebishopApprentice
It already supports it, just plug it in. Been running like that for two years or so.
- johnelexFollower
I agree that products like the Orbi and other mesh type system will work in the right home but each has it's set of limits. This can not be help in their design you must have a radio link between stations and a 2.4 ghz with a 5ghz band plus the electronics and antennas. All this takes processing time on each device that slows down the whole system and limits their range.
It would be great to have this capability for SXR80 (which is not covered by this article https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System?article=000051205); even having the option to completely disable WiFi backhaul connection per satellite.
SXR80 supports ethernet backhaul already.
Doesn’t work for me in any consistent way despite using the latest firmware (at the time I’m writing this comment). And this even after factory resets and countless reboots.
Enhanced the request to explicitly disable WiFi backhaul to force Ethernet backhaul.
Please make a new post here and lets trouble shoot this.
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Ethernet backhaul has been supported since the SX series first came out. I know my SXK30 series works.
Disable of wifi BH can't be supported as the BH needs to be enabled all the time is case the wired back haul fails, the system has something to fall back on. Not needed as well. BH support is automatic, and doesn't need any forcing.
- AncientGeekApprentice
I moved to Ubiquiti three years ago and have great flexibility with AP styles and connectivity.
