Would really enjoy if the Orbi was offered in a few different colors, the classic options are of course a Black which will probably blend in better with many customers current equipment. My entire AV...
Stenn
Sep 08, 2019Novice
SOLUTION!
Pick the trouser sock of your choice. For you dudes a trouser sock is a thin, almost hosery/nylons type of sock. Cut the toe off and stretch it over your WHITE device. The thinner you stretch it the more translucent it becomes.
Voila...looks kinda like a speaker panel fabric if you use black.
