demonic1
Dec 28, 2016Star
Status:
Engineering Investigation
Never rebuild a configuration from scratch again!
I understand that a developing product needs updates. Sometimes these updates require changes to what data is expected for an element of the settings config. As a customer, when a firmware update i...
William10a
Feb 09, 2017Master
From I see if you just update your firmware the basic settings should be the same unless they add a function or remove.
