demonic1
Dec 28, 2016Star
Status:
Engineering Investigation
Never rebuild a configuration from scratch again!
I understand that a developing product needs updates. Sometimes these updates require changes to what data is expected for an element of the settings config. As a customer, when a firmware update i...
William10a
Feb 13, 2017Master
One possible answer is divide home into classes one with the basic functions , another with nas and same advance router functions and the top of the line serials with every thing in the on it. At least if you update your router with faster one in the same class the control panel should not change other just or two new settng that could filled in.
