demonic1
Dec 28, 2016Star
Status:
Engineering Investigation
Never rebuild a configuration from scratch again!
I understand that a developing product needs updates. Sometimes these updates require changes to what data is expected for an element of the settings config. As a customer, when a firmware update i...
michaelkenward
Nov 03, 2017Guru - Experienced User
it is easy to provide customer that solution by rethinking completly the way they managed their devices
The idea that "it is easy to provide" this change is at odds with the suggestion that the answer is "rethinking completely the way they managed their devices".
The concepts "completely rethinking" and "simple" do not belong in the same sentence. If it were that easy, it would have happened.
Let's keep this discussion in the real world.
