ryansandberg's avatar
ryansandberg
Follower
Oct 26, 2020
Status:
New Idea
Nighthawk App Compatibility Request
Could you please develop the Nighthawk App to be compatible with the C7100V-100NAS gateway? It is frustrating that I can't have any network administration controls for a $300 gateway
1 Comment
Comments have been turned off for this idea
  • michaelkenward's avatar
    michaelkenward
    Unfortunately, app support depends on firmware and most Netgear cable modem devices do not allow firmware updates. That's down to the ISPs.
    You may be able to do remote management using a browser and aimimg that at your modem/router.
    See Remote Management in the manual.
    Visit the support pages:
    Support | NETGEAR
    and feed in your model number and check the documentation for your hardware.
