nicolassp's avatar
May 10, 2016
Status:
Unspecified
Nighthawk D7000 Guest Network with Different DHCP Pool
Hello, i notice that when enabling Guest network then there is no option to set bandwidth limit and different dhcp pool. For example i want my main network to be on 192.168.0.x pool and my guest network on 192.168.2.x pool with a certain bandwidth limit. If this capability is not present i hope to be integrated in next firmware update.
Thank you.
3 Comments
Comments have been turned off for this idea
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello nicolassp
    That is correct we do not have this option on the router but its a great Idea you should post this and any other ideas like this on our idea exchange board.
    DarrenM
  • I have posted it but i did not receive an answer if it is gonna be implemented. I hope so though..
    Best regards
  • Add on a schedule for Guest network activation times!  I want to turn it on for home office meetings and then have it automatically turn off later.
