SamDs
Jul 17, 2020Follower
Status:
New Idea
Nighthawk Mesh WiFi 6 system needs separate 2.4 and 5.0 SSID
Would like to buy Nighthawk Mesh WiFi 6 system but I'm afraid it will not fit my needs. My new DVR TiVo Bold+ can connect via either 2.4 or 5.0. Of course, download speed is far better at 5 Ghz. U...
ashorty
Oct 03, 2020Follower
Hello Netgear,
Is there any plan to support switching on/off/separating the 5GHz frequency on the nighthawk MK63 mesh system?
It seems many devices (such as Nest Protect) which can only use the 2.4GHz frequency cannot connect. If there is no plan to add support, I will have to return the MK63.
Thanks for any further information.
