SamDs
Jul 17, 2020Follower
Status:
New Idea
Nighthawk Mesh WiFi 6 system needs separate 2.4 and 5.0 SSID
Would like to buy Nighthawk Mesh WiFi 6 system but I'm afraid it will not fit my needs. My new DVR TiVo Bold+ can connect via either 2.4 or 5.0. Of course, download speed is far better at 5 Ghz. U...
gregc007
Nov 13, 2020Novice
My sonos is having problems at the 5ghz band. All SONOS troubleshooting seemed to be at the 2.4ghz band.
From SONOS
Here are router settings that need to be verified. You can contact your ISP or the manufacturer of the router for assistance.
a. Auto channel must be set to Off
b. Choose best non-overlapping channel (1,6,11)
c. Set channel bandwidth to 20MHz
d. Both 2.4GHz and 5GHz should be enabled
e. UPnP should be enabled
f. 802.11 band should be set to b/g/n
Thank you for your time and enjoy your Sonos!
