SamDs
Jul 17, 2020Follower
Status:
New Idea
Nighthawk Mesh WiFi 6 system needs separate 2.4 and 5.0 SSID
Would like to buy Nighthawk Mesh WiFi 6 system but I'm afraid it will not fit my needs. My new DVR TiVo Bold+ can connect via either 2.4 or 5.0. Of course, download speed is far better at 5 Ghz. U...
figurefive
Mar 15, 2021Fledgling
I would like to see this enabled as well. There was a commandline work around for the Orbi system to accomplish this.
The problem I am having is my Oculus Quest flips out after a bit of time and loses the WiFi connection. It's something to do with it momentarily seeing the 2.4 connection as better and attempting to switch. The switch fails and the Quest disconnects. I can sometimes reconnect right away. Sometimes I need to forget the connection and re-enter the password. It's a known issue with the Quest, but Oculus seems disinclined to fix it. When I split the 2.4 and 5 networks on my Orbi the Quest worked great. I need the added WiFi bandwith of the Mesh 6, though.
