Requesting the ability to split the 2.4 and 5ghz bands to seperate SSID's.
prakkie
Jul 06, 2021Onlooker
I want to have separate SSID for all IoT devices which I prefer to be as 2.4GHz band. Initially, I thought of using Guest SSID for this purpose. However, I tend to cycle Guest SSID password periodically. When I do so, I will end up in relogin at every IoT devices. Instead, if I have a separate SSID which I can retain just for IoT devices, which will reduce the pain of relogin. Hence, requesting to have separate SSIDs options. Thanks.
