I believe this is a "simple" feature that should be available on Nighthawk routers:
Being able to create VLANs on the LAN side (Ethernet and WiFi). Ideally with VLAN routing capabilities.
NETGEAR ProSafe routers that cost less than Nighthawk routers have this, but not on WAN side, which is the opposite situation.
For my setup, I'd like to use separate VLANs for the WiFi, my wired network and my servers. On an expensive router, I don't think this is an unreasonnable expectation. Unfortunately, it's not possible on the R7000.
1 Comment
- NETGEAR_TeamCommunity ManagerStatus changed:UnspecifiedtoNew Idea
