I've had two USB thumb drives overheat and crash (consistantly). Here are the model numbers:
1.) A super-mini thumb drive by Lexmark (32GB, USB3.0 JumpDrive S45 - LJDS45-32GABEU (I liked the low profile, but it clearly couldn't dissipate heat as the USB port on the R9000 is recessed...
2.) A longer thumb drive by Sandisk that has a metal housing (32GB USB3.0 Ultra Flair SDCZ73-032G) which I thought could dissipate heat, but it just can't...
The only solution to this is a USB extension cable.
NetGear's KnowledgeBase regarding "tested USB drives" is terribly short, and woefully incomplete:
https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
(it refers to the "SanDisk 64GB" as being compatible, but it DOES NOT give the model number like it does for every other device listed)
The R9000's two USB3.0 ports are positioned under the router's overhanging plastic chasis. This does not allow for heat to disapate from the pen drives, which become too hot to touch. I recomend that future models have the USB ports flush with the router's outermost walls.
Comments have been turned off for this idea
