I would be great if you had a compatible satellite to the Orbi 970 that is outdoor rated. Daze
Apr 28, 2025Guru - Experienced User
Not sure if NG will be putting forth any more outdoor units for home systems.
However if you need something to provide some outdoor signal for coverage, you can look into WAX6##Y series outdoor APs.
