If you have your orbi on a shelf above eye level (like I do), you will never be able to view the colored status indicators located at the top of the device.
Recommend that ring be made so it is visible from the front of the Orbi, not just from the top looking down.
A translucent top edge of the Orbi would do this just fine.
My ISP went down the other day and I could not see the ring that had appeared on the RBS50 because it sate higher than eye level on a shelf in my office.
Comments have been turned off for this idea
