It would be useful in the GUI (and perhaps app) to have the ability to turn off specific wifi band radios temporarily.
As an example, turn off the 5g radio.
This would be useful in settin...
Aug 09, 2019Guru - Experienced User
FYI, for users who are trying to get some 2.4Ghz supporting only devices setup on there Orbi's you don't have to separate the SSIDs. You can however disable the 5Ghz SSID from being seen temporarily by setup devices. Under Advanced Tab/Advanced Settings/Wireless Settings. Take the check mark out of the Enable SSID (5G) box. This will hide 5Ghz SSID support for any 5Ghz supporting setup devices and force them to connect to the 2.4Ghz SSID frequency. This should allow the 2.4Ghz setup software on the mobile device to fully discover the 2.4ghz device and get it setup correctly on Orbi. Once completed, Check mark the Enable SSID (5G) box to put the Orbi back in normal operation.
Good Luck.
