RBK852 - the AX6000 system - Many devices in a home do not move. I've found the Orbi system decided to connect some devices to an Orbi access point that is farther away from the one near it. Wouldn't be a problem if the signal and connected speed weren't lower than they should be. To the point where some devices are either slow to gain access to, or they fall off the network.
I'd like one or two features added to the Orbi app / web set up.
- Allow users to manually move devices from one access point (Satellite/Router) to another.
- If need be - ask if device is normally stationary like cameras, wall switches, smart plugs, etc.
- Set the Orbi firmware to re-configure the network if a device has a low signal to the network. Send it to a different Satellite or Router. Note if signal increased or decreased and keep it or change it back if it was worse.
Comments have been turned off for this idea
