Please make a update for the Orbi RBR20, so we can separate the 2.4ghz and 5ghz SSID's.
I want to chose on each device wich network it will be connected to. So the 5.0ghz network will be clean ...
taurus850512
Mar 18, 2020Onlooker
rbk50也需要,2.4g信号好,但太慢了,离分机远一些会自动连上2.4g 速率只有5m/s 如果能连上5G 速度可达到25m/s 所以为什么不能让用户选择连接哪个???
另外,我在老版本已经通过Telent解决分开ssid了,为什么后台要给我自动更新?是否更新不是应该我说了算吗???
RBK50 also needs, 2.4 g signal is good, but it's too hard, the remote will automatically connect to 2.4 g at only 5M / s if you can connect to 5g at 25M / s, so why not let the user choose which connection to connect to? ?? In addition, I have already solved the split ssid by Telent in the old version, why should the background give me an automatic update? Shouldn't I be in charge of updates? ?
