Please make a update for the Orbi RBR20, so we can separate the 2.4ghz and 5ghz SSID's.
I want to chose on each device wich network it will be connected to. So the 5.0ghz network will be clean ...
jetter2
Apr 07, 2020Tutor
100% agree, we should be able to split our SSIDs based on being on 2.4GHz or 5GHz.
I would also like the ability to select 20/40/80MHZ channels for the backhaul channel width, as well as the center frequency!
