Please make a update for the Orbi RBR20, so we can separate the 2.4ghz and 5ghz SSID's.
I want to chose on each device wich network it will be connected to. So the 5.0ghz network will be clean ...
Corinb
Jul 02, 2021Novice
Would Like To see Split Option On All Other Routers Including Mr60 As Many Devices Such as security cameras require this. Without This The Router Is Useless And Need To Return.
