Please make a update for the Orbi RBR20, so we can separate the 2.4ghz and 5ghz SSID's.
I want to chose on each device wich network it will be connected to. So the 5.0ghz network will be clean ...
LockitupOz
Oct 27, 2021Fledgling
I finally worked out how to fix my issue. Courtesy of the "Google Nest" team.
Did you know that if you put your iphone in airplane mode, then connect to wifi, it will ONLY connect to a 2.4Ghz network!!
Fixed my drama of needing to avoid the 5GHZ to connect a Nest Protect!!
WINNER - Google...... Loser NETGEAR
