Although automatic firmware updates should probably be the default, there should be a method (easily accessible in the firmware settings) to disable firmware auto-updates. The foregoing would all...
danno18
May 01, 2018Initiate
I can't agree enough. 2.1.4.10 broke my ethernet satellite backhaul for my Orbi system and caused the entire network to lose connection to the Internet. Spent hours troubleshooting. Netgear support had me manually downgrade to 2.1.3.4 to veriy that etherenet backhaul works on that version (yes), but the auto update overwrote my downgrade in less than an hour. So I cannot use ethernet backhaul from my satellite nor can I even leave the ethernet canle connected to it without the network going down. The wifi speed from that distant satellite is <10% of the speed I get from the main router. Terrible.
