Although automatic firmware updates should probably be the default, there should be a method (easily accessible in the firmware settings) to disable firmware auto-updates. The foregoing would all...
danno18
May 01, 2018Initiate
Note that manual downgrade is only temporary, because the auto update will overwrite your downgrade. My manual downgrade lasted less than one hour before the auto update overwrote my manual downgrade, so I am stuck on 2.1.4.10.
