Although automatic firmware updates should probably be the default, there should be a method (easily accessible in the firmware settings) to disable firmware auto-updates. The foregoing would all...
Almighty
May 08, 2018Tutor
This needs to be implementer a.s.a.p.
Since the new FW usually doesn't work as they should we must be able to stop the router to auto update
2.1.4.10 has been a disaster and I need to revert to older FW all the time due to the auto update.
