Although automatic firmware updates should probably be the default, there should be a method (easily accessible in the firmware settings) to disable firmware auto-updates. The foregoing would all...
nbuubu
Jun 01, 2018Guide
After the latest update broke communication with my thermostat for some unknown reason, I had to muck about with telnet to try to block further updates. Really should give customer a cleaner way to disable updates. If it's working for us, I don't understand why Netgear insists on possibly breaking it by forcing updates.
