Although automatic firmware updates should probably be the default, there should be a method (easily accessible in the firmware settings) to disable firmware auto-updates. The foregoing would all...
Cooty
Nov 13, 2018Follower
Yes, the instructions for setting the nvram entries were ones I tried. It seemed to work for a while, but I've definitely had a firmware update pushed on me since then. Oh well.
