Although automatic firmware updates should probably be the default, there should be a method (easily accessible in the firmware settings) to disable firmware auto-updates. The foregoing would all...
Apr 22, 2019Guru - Experienced User
DorkiOrbiFW Ya my bad, I just loaded mine to check and I don't see any kind of option to disable Auto Update. Seems that SW_ has given mis-information....:smileyfrustrated:
I just updated the RBK50 system I have to v48 and it's working well. Manual FW file load on the units then full factory reset and setup from scratch. No problems thus far.
