Although automatic firmware updates should probably be the default, there should be a method (easily accessible in the firmware settings) to disable firmware auto-updates. The foregoing would all...
DorkiOrbiFW
Apr 29, 2019Apprentice
SW_ , while it may please some to enable this feature, you really do not need to. Ever since the release of firmware version 2.3.0.28, your Orbi system should no longer auto-update. However, in the act that it does, great work in finding the necessary commands necessary to enable this via telnet. Even though I know Orbi in the inside (telnet), I wouldn't have come up with this, so I thank you for sharing and outlining what's needed to enable the hidden feature.
Thank you,
The Orbi Mechanic (@DorkiOrbiFW)
