Although automatic firmware updates should probably be the default, there should be a method (easily accessible in the firmware settings) to disable firmware auto-updates. The foregoing would all...
DorkiOrbiFW
Apr 29, 2019Apprentice
SW_ ,
You are absolutely correct as there was one of my satellites that did auto-update to 2.3.1.44, although I haven't had any other satellite do it. I just wanted to let you and others know that the Orbi shouldn't be auto-updating after FW 2.30.28.
It is always “Better to have, and not need, than to need, and not have.”
:smileyhappy:
Have a good one,
