can you enable usb to work with hard drives
5 Comments
TOTALLY agree!!!
For me, the USB port worked for a few months! I had an old WD USB 2.0 hard drive attached as music library for my SONOS! Believe me it worked! only for a few months.
Dont have no idea why it stopped working. Even tried factory reset the router, no luck.
I know some folks never had luck using the USB port.
How come it worked for a while and then quit?!?!?!
Bummer!
- samor23Tutor
it doesnt make any sense
- fvr173Novice
This is a must and all it should take is a firmware update. Why not support something that is on most all of your other (less expensive) routers?
- samor23Tutor
come on netgear!
