NETGEAR Home and Mobile content has changed location. You can find troubleshooting, questions and support resources at https://www.netgear.com/support/home/
DESIi1's avatar
DESIi1
Star
Dec 12, 2016
Status:
Unspecified
Orbi WiFi Channels
Why would the Orbi router and satellites use the same channel?  There are three WiFi in my home, all on the same channel.  That goes against all convention!  The Auto or another setting should separate the channels to 1, 6 & 11.
It drives me crazy seeing all three graphically stepping on each other.
Comments have been turned off for this idea
