Router - Orbi RBR753 (AX4200) Firmware version - V4.6.5.14 Main OS for my devices - Windows Under wireless settings configuration; it should have an option to use WPA2 + WP3 as one of the security...
uSlackr
May 15, 2024Aspirant
Great to hear. The config options just says WPA3. Do I assume that's the correct option? The hover help doesn't mention it. ( WPA3-Personal- This type of security enables WiFi devices that support WPA3 to join the router's WiFi network. WPA3 is the latest security standard and is more secure than WPA2.)
I'm on 4.6.14.3_2.3.12
