Router - Orbi RBR753 (AX4200) Firmware version - V4.6.5.14 Main OS for my devices - Windows Under wireless settings configuration; it should have an option to use WPA2 + WP3 as one of the security...
uSlackr
May 15, 2024Aspirant
Thanks. I ran the updates (but did the router first) an all is well. WPA2 & 3 mixed mode enabled. Toyed with the new iOT feature, but it appears mostly window dressing, so it is back off.
