ncimino2
May 05, 2020Follower
Status:
New Idea
Please allow for separate 2.4Ghz and 5Ghz SSIDs on Nighthawk MR60
Please allow for the ability to separate the SSIDs for the 2.4Ghz and 5Ghz frequencies on the Nighthawk MR60. There are some smart home devices that only work on the 2.4Ghz band.
michaelkenward
Jul 12, 2020Guru - Experienced User
99 times out of 100, this is a total red herring.
There are very few instances, and arcane ones at that, when this is really needed. Just read the various discussions on the community for how to set up devices by temporarily disabling the 5 GHz ssid for example.
