ncimino2
May 05, 2020Follower
Status:
New Idea
Please allow for separate 2.4Ghz and 5Ghz SSIDs on Nighthawk MR60
Please allow for the ability to separate the SSIDs for the 2.4Ghz and 5Ghz frequencies on the Nighthawk MR60. There are some smart home devices that only work on the 2.4Ghz band.
schumaku
Jul 12, 2020Guru - Experienced User
dkmoody98133 create a thread in the Nighthawk Mesh community exacty describing the WiFi client you have an issue with. Many wireless client adapter need a driver for sucessful connection to WiFi 6 systems - alternate is disabling AX. Wrong section here for assistance.
