Hi, Netgear, Can you bring 5G to WiFi 6e mesh system, basically something like NBK752 but with WiFi 6e instead if just WiFi 6? Thanks, Yen-Ming
Jul 25, 2023Guru - Experienced User
5Ghz is already built in to the WiFi 6 and and 6E specs. 6 is just a AX mode. 6E is 6Ghz over AX mode.
Once products are built and release, nothing new can be added like 6Ghz as that takes a HW change.
