Hi, Netgear, Can you bring 5G to WiFi 6e mesh system, basically something like NBK752 but with WiFi 6e instead if just WiFi 6? Thanks, Yen-Ming
leeym
Jul 26, 2023Follower
MR6500 is indeed a mobile router that supports both 5G and WiFi 6e, but not included within Orbi mesh system.
What I am looking for is similar to NBR750 with WiFi 6e, so it will support 5G and WiFi 6e, and work with other mesh satellites.
The end-goal is to cover all my working area (mesh), with fastest possible speed (WiFi 6e) and can failover to cellular network (5G) if the primary connection is down.
