More UI/UX confusion: Why is wireless setup on two different pages, ie:
Advanced > Setup > Wireless Setup
and
Advanced > Advanced Setup > Wireless Settings
Again this is poor UI/UX menu design. There is no real difference between Setup and Settings. This is the Advanced side of the interface. Put all wireless settings on one page. As it is, one has to check both pages to find where to find a setting.
(v1.0.2.62 firmware)
1 Comment
Comments have been turned off for this idea
- snahtaFledgling
Hi,
I am also facing the same issue while using the UI UX design menu, but i think you should try other menu on this community or same menu with other options.
