Open Side Menu
Skip to contentBrand Logo
COMMUNITY
MY NETGEAR
SUPPORT
KNOWLEDGE BASE
NETGEAR APPS
Chinese (Simplified)DutchEnglish (US)FrenchGermanItalianJapaneseSpanish
RegisterSign In
  1. NETGEAR Communities
  2. Welcome to the NETGEAR Community
  3. Home Solutions
  4. Submit Ideas for Home Products
NETGEAR Home and Mobile content has changed location. You can find troubleshooting, questions and support resources at https://www.netgear.com/support/home/
aalexandrebeta's avatar
aalexandrebeta
Master
Mar 04, 2017
Status:
Declined
Power supply for router purchase directly from Netgear,
it would be great to purchase directly from Netgear power supplies for routers like they are doing at Dell,
William10a's avatar
William10a
Master
Mar 08, 2017
The strange thing a wndr3400 power which is a switch mode power supply least for years in must cases I believe the true problem is not the power supply itself all switch mode power supply convert ac to dc and drive a transformer to product the normal 12 volts that most netgear routers use.
The problem is the people who make the power supply and the quality of the parts used a part rated for 85 degrees will not last of long as rated for 105 degrees. Heat can break down anything if heat enough and long enough.
I have found that the longest lasting and easiest t find are laptop style power supplies they have bigger heat sinks and better design on ebay.
