Ok so I have seams some topics in reference to VPN services but it would be a good enhancement if the router can segregate which devices utilize the VPN connections and which ones are excluded in devices. Right now, it is all or nothing approach. I would like to either setup a rule in which devices you require to use the service that is installed on your nighthawk netgear router or select all devices.
I like the ability to segregate some of my streaming devices in which it will not use the service but all other devices on my network will utilize the VPN Service.
Comments have been turned off for this idea
