peelio72
Mar 22, 2016Follower
Status:
Unspecified
Question about using a wireless connection to connect wired devices
So I have a wireless router connected to my cable modem. This provides my wireless network for the house. What I need is a wireless connection for my Blue Ray player (it's an older sony). So I tried using another wireless router to connect to the EXISTING network, but couldn't get it going.
So what is it I need that I can configure to connect to the Wireless network to provide a wired access point for my Blue Ray player? Again, there is to be no wired connection between my existing wireless router and the new switch that I will be placing in another area of my home...
Thank you for the help in advance!
Chris
2 Comments
Comments have been turned off for this idea
- If your Blu-Ray player has an Ethernet port, then the Netgear WNCE3001 should work. A range extender will also work.
- William10aMaster
An power line adaptor is another.
