I just upgraded to firmware version 1.0.7.2 as I wanted to enable Smart WiFi on my router. This new firmware lists one of the changes as improved QOS GUI.
I feel that the QOS settings is now much worse and unusable for advanced users.
I have many custom upstream QOS rules which I need to enter and specify myself.
I am unable to do this as even after removing all the pre-activated QOS rules, what I am trying to add apparently conflicts with an existing rule, BUT there is no way to view the ports/protocols of the preinstalled QOS rules, nor is there any way to remove them. I then tried to add another rule and got another message to say the rule already exists by name but it was not in the list of rules.
It's not a problem to have pre-activated rules, or to have pre-set rules avaiable, but to not be able to remove the pre-set rules or even view what they are to find what is conflicting when trying to set up a new rule makes this useless for more advanced use.
Please can we be able to create our own custom rules even if they cover or partially cover the same ports as the pre-set ones, or can we just delete the pre-set rules if we need to? Yes I know we can delete them from being activated, but even when they are not being 'used' they stop you adding your own if the ports are in the pre-set ones.
I can't manually add the rules I want, neither can I confirm if they are covered by the pre-set rules as I can't see what they are.
I had to go back to old firmware version V1.0.4.30_1.1.67 which does allow me to set things how I need.
Please can this be looked at for a future firmware version?
1 Comment
Comments have been turned off for this idea
- AncientTomNovice
Here it is April 2, 2019. My R7000's firmware is the latest update, and this issue is still a problem. I too have to set priorities throughout my home and the first entry for my home's VoIP PBX I cannot set because of this same issue of hidden router presets in the firmware. CAN YOU FIX THIS ASAP?
