Collector123
Feb 15, 2016Initiate
Status:
New Idea
R8000 Guest Network Needs Separated Wireless Isolation and Local Network Access
Guest Network now combined the 2 functions "Wireless Isolation" and "Local Network Access" as a single option. In the old days, they are separate options. My Chromecast does NOT work on Guest Net...
bewilder1
Dec 23, 2021Novice
Long time Netgear fan/customer. It's bonkers that these two settings are not separated! Need to disable network isolation in the guest network (allow guests to connect to each other) while enabling firewalling between guest and private network. Currently using Orbi RBK50.
