kielwarwick's avatar
kielwarwick
Follower
Mar 02, 2024
Status:
New Idea
RAX120 USB HDD SLEEP
This should be an easy change to add the ability to set a sleep timeout for USB attached hard drives. My RX500 nighthawk would alow my attached drive to spin down when not in use (which is most of the time). I upgraded to the RAX120 due to its 5g port and higher data transfer rate on the USB drive but it is very wastful to have the drives spun up 24/7. I am extremely disappointed with this inefficient oversight.
Comments have been turned off for this idea
