Retired_Member's avatar
Retired_Member
Sep 13, 2019
Status:
New Idea
Rax120 WAN and LAN at the same time
Would like to see the ability to have WAN and LAN aggregation on the RAX120 to be able to be used at the same time. Other brands of AX routers can do this.
3 Comments
Comments have been turned off for this idea
  • Retired_Member's avatar
    Retired_Member
    The Asus ty-AX88u does for sure and the TP-Link AX router does as well.
    Retired_Member
    The Asus RT-AX88 uses ports 1 and 2 for LAN aggriation and the WAN and port 4 for WAS aggregation.
