akt111
Jun 10, 2020Tutor
Status:
New Idea
RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router - Parental Controls
I purchased the RAX-45 router with an understanding that it will support some good parental controls, through the Nighthawk app as advertised under the below link. The link does not outline it very e...
sambared
Nov 18, 2020Initiate
facing same problem here. when are you going to add parental controls to Nighthawk RAX45??????? purchased for $200 but no parental controls SHAME SHAME..:smileyhappy:
