It would be nice if there is an option to separate the 2.4 GHz and 5GHz bands because the autolselect isn't working proppely on streets with havely crowded 2.4GHz band.
michaelkenward
Nov 19, 2022Guru - Experienced User
brucewboyer
I'm trying to separate the 5g and 2.4g and the instructions I found were to enable telnet.
If you want help with your device, try posting in the section where they support it. This place is for product suggestions, not questions about how to separate the 5g and 2.4g.
