MEDUCK7's avatar
MEDUCK7
Tutor
Mar 07, 2021
Status:
New Idea
Read SMS message from LBR20 or App
Hi all,
I would like to  suggest to create the function to read the SMS message and the user can read the SMS via the router or app directly.
do you need this funciton too? wish they can receive the suggestion to possibly be implemented soon.
2 Comments
  • You can find SMS messages via orbilogin.com > Advanced > Advanced Setup > SMS Message.
    I am curious why Netgear does not offer this in the Orbi app?!
    Also, the placement under "Advanced Setup" is odd, because there is nothing to set up with regard to SMS messages.
