Suggest that the R7200 model of AC2100 support ReadyShare Printer.
michaelkenward
Jun 27, 2020Guru - Experienced User
According to the manual, it does.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Check the section in the manual, Share a USB Printer.
